Shoutbox doesnt work
Been banned or need help, server down? - post here
Orock
Postby Orock » Mon Jan 18, 2010 11:52:08
I can't seem to use the shoutbox.
When I press enter or click the submit button I just get to a new page with the shoutbox in it and the button will be gone.
Seems to happen in both IE8 and IE7.
I don't wanna be forced into using firefox and it should work if the code is following w3c rules.
Please help? :P
Re: Shoutbox doesnt work
Postby B00rz » Mon Jan 18, 2010 12:20:26
Doesn't seem to be any problems for me tested it out using IE7 on my crappy win98 machine at work and its fine
Postby King » Mon Jan 18, 2010 12:34:29
Orock wrote:I can't seem to use the shoutbox.
Please help? :P
can't find any issue with it. also if it follows w3c rules it won't work correctly in IE, cause IE doesn't follow them =P
Orock
Postby Orock » Mon Jan 18, 2010 12:45:32
Well either way it doesnt work for me.
The IE7 is at work and the IE8 at home, so its even seperate environments.
But Ill see if I can get some more info to find a solution.
Postby King » Mon Jan 18, 2010 13:21:58
Having just tested it again, it appears to only happen in the 64-bit version of IE. God knows why that'd make any difference, but apparently it does. the behaviour on the 64-bit version makes no sense. it shouldn't go to the shoutbox page at all =P
Side note: Shoutbox is now limited to displaying the most recent 30 shouts, may edit that number later but seems reasonable atm.
Postby Dimon » Mon Jan 18, 2010 14:22:08
Install Firefox, Opera or Chrome.
Orock
Postby Orock » Mon Jan 18, 2010 14:26:28
Are you actually telling me to install another browser because something doesnt work?
Maybe its just better to find the solution?
Not nice to make something to tell a customer: "oh well sorry doesnt work on your browser, just use another"
But since at work my internet is through Citrix I have to wait till I get home to see what the actual problem is.
I'll let you guys know =)
Postby Rza » Mon Jan 18, 2010 14:45:37
Not to be rude but we aren't a shop, and you are not a customer, so i don't really get why your giving us the TCF stuff. Changing code for 1 person is most likely an extreme amount of hassle for jonnie to fix for a really small part of the site that's just random rubbish posted on it. Of course it's personal preference what browser you use, but the simple fix is download another browser and view on it, if it matters so much.
Postby Dimon » Mon Jan 18, 2010 14:54:46
You should shy away from using IE anyway. :p
Orock
Postby Orock » Mon Jan 18, 2010 15:08:05
Nah I think you are getting me wrong.
I dont expect you to fix it for just me =)
Was just a bit annoyed by the short answer: go download another browser.
And tbh most ppl dont have a problem, so Im trying to find out why I do, thats all.
I hoped someone knew what the problem was and that isnt a helpful answer.
Again I don't expect anything, just was curious for myself what the actual "problem" is.
And I said Ill try to find it myself so if others have the same prob in the future they know why =)
I do have firefox btw so no worries lol
Return to Help / Support
Users browsing this forum: No registered users and 72 guests
