Graphic card switch
Been banned or need help, server down? - post here
Re: Graphic card switch
Postby Dimon » Fri Mar 02, 2012 13:23:43
Dimon wrote:Monitor
MidiTower Quite spacious for this price segment.
I'd swap it out with something else if you're getting a better GPU.
DVD
HDD
PSU
RAM
CPU
Motherboard
GPU'sX2
Totalt inkl. moms 11 515,00 SEK
No mouse and keboard since I have no idea what you'd like. :p
Monitor is not very good probably, but should be fine for gaming. CNET gave it a good reveiw score, but mine got a good score there and I'm not happy about the color quality...
Postby Dimon » Fri Mar 02, 2012 13:30:06
Zen wrote:4 things i would prolly change if it works :P
graphics - http://www.komplett.se/k/ki.aspx?sku=659717#extra
Monitor - http://www.komplett.se/k/ki.aspx?sku=635506
Chassi - http://www.komplett.se/k/ki.aspx?sku=605768
Ram - http://www.komplett.se/k/ki.aspx?sku=
prolly 1 extra HDD aswell but thats a later issue, since im not really in to all specs i hope these changes would fit in the MOBO :P
Chassi and monitor seems fine. The GPU is not really worth it imo since it's not really better then the two 560's.
And I forgot to specify two cards in my post sorry guise. ;d
Ram I don't know about since you forgot to put the product ID into the URL.
Just remember that the list of games you can use more then 4 GB of RAM for can just about be counted on one hand so far. :p
f1xxx3r wrote:Thought it was only one xD Didn't see the "'s" in GPU's :D
Yeah my bad for not specifying it properly. \o/
Postby Zen » Fri Mar 02, 2012 14:21:18
http://www.komplett.se/k/ki.aspx?sku=585022#extra
that should do it xD dont know how i managed to screw the first one up :P
Postby Dimon » Fri Mar 02, 2012 14:31:41
Oh and I chose Dutin because it's better then komplett. Been using komplett for over 10 years, now I use Dustin instead. Komplett may have one off offers that are better a couple of times each month but I find Dustin to be cheaper overall. ;d
The memory I linked is just as good as the ones you linked. :D
Postby Zen » Mon Mar 05, 2012 20:29:52
are you sure that the mobo takes the 1600 ram memory, says it only supports 1333 and 1066, maybe im lost but if the mobo only takes 1333 and 1066 can you jack in a 1600 and it works fine?
Postby Zen » Mon Mar 05, 2012 21:03:23
Also found this that is cheaper and i think its not far from using 2x dims choice
http://www.komplett.se/k/ki.aspx?sku=743397#extra
Postby Dimon » Tue Mar 06, 2012 02:02:22
Zen wrote:Also found this that is cheaper and i think its not far from using 2x dims choice
2 GB? You do realize at 1080p that wont really give any performance boost over 1GB of VRAM? You still need two of those to get the samme performance as the two 1 GB cards. ;d
Zen wrote:are you sure that the mobo takes the 1600 ram memory, says it only supports 1333 and 1066, maybe im lost but if the mobo only takes 1333 and 1066 can you jack in a 1600 and it works fine?
http://www.asus.com/Motherboards/Intel_ ... ifications
Dual-Channel DDR3 2200(O.C.) / 2133(O.C.) / 1866(O.C.) / 1600(O.C.) / 1333 / 1066MHz support
The motherboard supports DDR3 memory that features data transfer rates of 2200(O.C.) / 2133(O.C.) / 1866(O.C.) / 1600(O.C.) / 1333 / 1066 MHz to meet the higher bandwidth requirements of the latest 3D graphics, multimedia, and Internet applications. The dual-channel DDR3 architecture enlarges the bandwidth of your system memory to boost system performance.
So yes it does support 1600 MHz RAM. It quite normal for online stores to not have the full speccs listed for PC parts.
Return to Help / Support
Users browsing this forum: No registered users and 49 guests
