PC = Crazy
Been banned or need help, server down? - post here
Milki
PC = Crazy
Postby Milki » Mon Feb 23, 2009 17:21:45
My damn PC crashed!!!! first it restarted several times.. and then suddenly the screen went blue with some warnings and other stuff.. so i reinstalled Win XP.... after the reinstall i had to install other stuff like graphic card and sound drivers.. "Made Me Angry" Then suddenly...... THE BLUE SCREEN..... so i kicked my PC and reinstalled XP and drivers... SO! after 3-4 hours its working... Hopefully :shock:
Re: PC = Crazy
Postby Razerslash » Mon Feb 23, 2009 17:25:37
If you still think there is something wrong with it, download and install Teamviewer from teamviewer.com and I will check your PC out remote for free. Just make sure you let me know an appropriate time.
I have been installing WinXP for the company I work for and made images which do need to be very precise as they go on to about 2000+ PC's =P
Re: PC = Crazy
Postby Baby-Boo » Mon Feb 23, 2009 17:51:22
I used to use a program for CD burning that gave every of the 3 computers I tried it on the blue screen of death, although it was a temporary that could be fixed with a restart. Don't install those programs that are not very known or you feel could be dangerous.
One program had a virus that made my windows look like Windows 2000 after the restart... freaked me out :(
Re: PC = Crazy
Postby RandomTask » Mon Feb 23, 2009 18:46:46
Blue screen after reinstall with just drivers etc would soumd like a RAM problem to me.
Re: PC = Crazy
Postby Talho » Mon Feb 23, 2009 18:50:42
memtest86 !
Re: PC = Crazy
Postby Razerslash » Mon Feb 23, 2009 19:47:04
Nowadays its a hit or miss installing WinXP, if drivers are not correctly installed you will get BSOD and there is really nothing you could of done. Sometimes the installion could of gone corrupt. Also AV programs cause desaster too. Let us know how it goes, otherwise i'd take a look.
Milki
Re: PC = Crazy
Postby Milki » Mon Feb 23, 2009 20:23:17
Its working now :D when the blue screen showed up it said something about system32 and that it was damaged. well I am installing service pack 3.. the restart thing happened when i was playing Far Cry 2.. now i have too reinstall CSS and play on the server :ugeek:
Re: PC = Crazy
Postby RandomTask » Mon Feb 23, 2009 20:42:30
Service Pack 3 rapes your pc. Screws up DirectX etc. I wouldnt put it on if i were you. Raped my old PC twice in a row from fresh installs when I tried it.
Hooogan
Re: PC = Crazy
Postby Hooogan » Mon Feb 23, 2009 20:43:41
Delete System32.
It'll just bog down the PC.
return 0;
Re: PC = Crazy
Postby Razerslash » Mon Feb 23, 2009 20:54:57
SP3 fixes a winlogon error we kept getting at work. But when SP3 first came out, it was the biggest risk installing it because depending what you have installed some things will have stopped working altogether. But now its safe to install.
Return to Help / Support
Users browsing this forum: No registered users and 12 guests
