problems
Server Down? Performance issues? Been Banned? Any server related problems or ban appeals please let us know in here!
problems
Postby Zen » Thu Jul 19, 2012 20:32:31
So i got dayz now, managed to get into our server, and no weapons or nothing to defend myself with at start point, is it supposed to be like that couse i get raped by zombies if i move a few hundred meter in any direction......
Re: problems
Postby B00rz » Thu Jul 19, 2012 20:34:59
yeah you start with nothing. You need to crouch using X and walk slowly using shift
Re: problems
Postby Zen » Thu Jul 19, 2012 20:39:03
aha, then i dont have to think about that then, got some error message about weapons so tought i bugged out but if it supposed to be that way ill sneak arround some then.
Re: problems
Postby Rza » Thu Jul 19, 2012 20:53:49
Jump on TS and we can help you out.
Re: problems
Postby Zen » Thu Jul 19, 2012 21:26:38
ill be on TS after ive moved and got my mic and shit, 1 week to go then now :D and ill get a stable connection aswell then
Links
Re: problems
Postby Links » Thu Jul 19, 2012 22:23:14
you find everything in Dayz, so bags, guns,etc all need to be looted from buildings. zombie wise, best bet is just to rambo it into the nearest town/village and hope for a gun then just kill them once your equipped. Google dayz db maps, and find out where you are like. Helps alot. And like iain says playing with people is so much better/different!
Re: problems
Postby RandomTask » Thu Jul 19, 2012 22:28:03
Links wrote:best bet is just to rambo it into the nearest town/village and hope for a gun then just kill them once your equipped.
I prefer sneaking to the nearest dear stalker or two, unless I'm really close to a town then I just sneak to the fire station/school to try and get a pistol.
Re: problems
Postby Zen » Fri Jul 20, 2012 18:42:24
does one have to find a map to be able to use that function? Because when i open my map its all black so i got no clue where i am at all :S
Re: problems
Postby Rza » Fri Jul 20, 2012 18:49:43
you need to find a map to be able to use it.
http://dayzdb.com/map use this though out of game. It tells you were loot spawns.
The best thing to do is run to a town and find a signpost, look at the town name and find it on the map. That will get your bearings. You always spawn down at the south coast aswell btw.
Re: problems
Postby Zen » Fri Jul 20, 2012 18:51:28
alrighty then, thx :)
Return to teamafx.net DayZ Server Support
Users browsing this forum: No registered users and 6 guests
