corrupted images while browsing
Re: corrupted images while browsing
Postby Dimon » Sun Nov 20, 2011 00:25:10
fops wrote:Also both on wifi and cable ;)
It seems to be some sort of transmission failure.
Browsed imdb earlier and got random html code instead of proper rendered pages.
Also it doesn't happen on all images. The reddit header being the stubborn one and still showing up corrupted.
After a bit of research I'd try installing CCleaner and delete IE's index.dat file from there... Looks like it worked for someone using XP that had the same problem. :lol:
Rza wrote:
fops wrote:In all browsers
I R smarts. Evidently...
Postby fops » Sun Nov 20, 2011 01:01:06
Did a bit of research aswell before asking on the forum.
Already run CCleaner, deleted everything and stuff. Still the same
Really don't want it to break, I do my work on it and I don't have a valid replacement, as my pc is just a dust collector
Postby Dimon » Sun Nov 20, 2011 19:25:59
fops wrote:Already run CCleaner, deleted everything and stuff. Still the same
You ran CCleaner with the delete index.dat option checked? :p
Postby Zen » Sun Nov 20, 2011 19:43:10
could be internet probs aswell, problem with data transfers etc i would guess on if you checked your comp. talk to the internet provider and check if they can see anything wrong :D
Postby fops » Sun Nov 20, 2011 21:27:25
I think we read on the same forum actually.. That's the reason I tried CCleaner
Don't know about internets yet, I'll check later
Postby Pride » Mon Nov 21, 2011 22:25:05
Most likely a firewall issue causing packet loss, which causes insufficient image pixels to be displayed on your screen. If this is a graphics card issue, you should check your monitor settings --> advanced --> color control --> make sure perceptual is set to photography and absolute colorimetry is set to highest.
Also, before doing that, I suggest you click this first:
http://i.imgur.com/bEc94.jpg
Postby f1xxx3r » Mon Nov 21, 2011 23:32:17
Pride wrote:Most likely a firewall issue causing packet loss, which causes insufficient image pixels to be displayed on your screen. If this is a graphics card issue, you should check your monitor settings --> advanced --> color control --> make sure perceptual is set to photography and absolute colorimetry is set to highest.
Nice one Pride!
Postby King » Mon Nov 21, 2011 23:38:02
That image has been so popular on reddit lately. Made me lol though ^_^
Postby fops » Tue Nov 22, 2011 11:54:10
You got me there, thought it'll be something serious. Well, actually.. it kinda is haha
Postby Pride » Tue Nov 22, 2011 21:34:10
The first one could actually be true. Are you behind a firewall?
Users browsing this forum: No registered users and 5 guests
