elstatsneo
Re: elstatsneo
Postby King » Fri Feb 13, 2009 00:20:43
hlstats.pl
HiTmAn
Re: elstatsneo
Postby HiTmAn » Fri Feb 13, 2009 00:36:59
when i run hlstats.pl i received this message:
"2009-02-13 00:07:01: - MYSQL: Connecting to MySQL database '*********' on '********' as user '**********' ... connected ok
2009-02-13 00:07:01: - CONFIG: Reading database config...
Config parameter 'DNSResolveIP' = '1'
Config parameter 'DNSTimeout' = '5'
Config parameter 'Rcon' = '1'
Config parameter 'RconIgnoreSelf' = '0'
Config parameter 'RconRecord' = '0'
Config parameter 'MailTo' = ''
Config parameter 'MailPath' = '/bin/mail'
Config parameter 'Mode' = 'Normal'
Config parameter 'SkillMaxChange' = '50'
Config parameter 'SkillMinChange' = '2'
Config parameter 'PlayerMinKills' = '50'
Config parameter 'DeleteDays' = '30'
Config parameter 'UseTimestamp' = '1'
Config parameter 'MinActivity' = '15'
Config parameter 'AllowOnlyConfigServers' = '1'
Config parameter 'TrackStatsTrend' = '1'
Config parameter 'GlobalBanning' = '0'
Config parameter 'LogChat' = '1'
Config parameter 'LogChatAdmins' = '1'
Config parameter 'GlobalChat' = '0'
Config parameter 'HLStatsXCountryMaster' = '0'
Config parameter 'MasterBanlistBantime' = '60'
2009-02-13 00:07:01: - CONFIG: I have found the following server configs in database:
2009-02-13 00:07:01: - S_CONFIG: 81.92.219.203:28275
2009-02-13 00:07:01: - ELSTATSNEO: ELstatsNEO 2.40 starting...
Can't setup UDP socket on port 27500: Address already in use"
so the problem now is the port, it isn't?
it's closed?
Re: elstatsneo
Postby King » Fri Feb 13, 2009 08:15:28
so it seems yea.
HiTmAn
Re: elstatsneo
Postby HiTmAn » Fri Feb 13, 2009 12:34:02
ok.. i'm waiting for webhost's admin to open port 27500..
king another question :p
when he open this port, what should i do?
only run hlstats.pl or run or kill other thing?
Re: elstatsneo
Postby King » Fri Feb 13, 2009 12:58:16
just hlstats is the only thing that needs to "run"
all other stuff is just configurations or stuff to enable it to be viewed on the web pages.
HiTmAn
Re: elstatsneo
Postby HiTmAn » Fri Feb 20, 2009 17:42:23
its done :D
thanks for your help king..
this is the page..
http://snaky.centelia.net
i have a last question.. ^^
why is all accuracy players a zero?
Users browsing this forum: No registered users and 13 guests
