Skyrim
Re: Skyrim
Postby B00rz » Fri Nov 11, 2011 18:17:50
couldnt play when it came out last night because my sound quality was set too high. To me that is just stupid
Re: Skyrim
Postby Pride » Fri Nov 11, 2011 19:09:05
I'm still patiently waiting for Zelda: Skyward Sword.
*puts on flameshield*
Re: Skyrim
Postby Dimon » Fri Nov 11, 2011 20:07:08
Heard it's pretty good Pride. ;d
Re: Skyrim
Postby Rza » Fri Nov 11, 2011 21:59:28
B00rz wrote:couldnt play when it came out last night because my sound quality was set too high. To me that is just stupid
Re: Skyrim
Postby B00rz » Sat Nov 12, 2011 05:13:49
it crashes if you have your sound quality in windows set to max. you need to set it at something like 16-bit 48000
Re: Skyrim
Postby RandomTask » Sat Nov 12, 2011 10:35:50
B00rz wrote:it crashes if you have your sound quality in windows set to max. you need to set it at something like 16-bit 48000
pwnt.
Re: Skyrim
Postby Rza » Sat Nov 12, 2011 13:14:23
This is really the first RPG game I've played and really enjoying it so far.
One problem being I went into a pit that I assume thats some sort of dungeon, and I can't get back out again because the entrance you jump down is a hole that can't be climbed back up, the only way out is the other side. all the monsters inside it are way to powerful for my character to kill in numbers and I don't have any saves, saved outside it so I think am gonna have to start again and be wary of auto-saving in the future. Warning to all I guess that's planning to play it, manually save if your doing a bit of exploring and accidentally end up lost down a cave
Re: Skyrim
Postby Dimon » Sat Nov 12, 2011 13:23:36
MOAR SAVES!
Trust me, there's no such thing as too many saves in an elder scrolls game. ;d
Re: Skyrim
Postby Rza » Sat Nov 12, 2011 13:36:44
A Big SC2 streamer Destiny is streaming Skyrim in Full 1080p if anyone is interested:
http://www.teamliquid.net/video/streams/Destiny
Re: Skyrim
Postby bob » Sat Nov 12, 2011 15:58:03
if its anything like the other elder scrolls gmes u shud be able to hit ` then type TGM and run thru the place without dying to save starting again then do the same again to turn it off
Users browsing this forum: No registered users and 99 guests
