Postby Zen » Sun Sep 06, 2009 17:51:15
Dont forgett to tell us what you think about it when you got it up and running =)
Postby Baby-Boo » Sun Sep 06, 2009 18:21:02
Thanks and will do. Will be better watching movies from now on because they are so widescreen. Most animes are also widescreen now. And playing games, although I don't play on this computer because it's too weak to play anything new.
Haven't colored anything either, been waiting until I get a second monitor.
Postby Dimon » Wed Sep 09, 2009 01:24:51
HD version available! *drool*
Postby Baby-Boo » Wed Sep 09, 2009 14:43:29
I just got it. Man it's so wide. When I drew it on paper, I also took the size of the stand, so I thought it was really square. It's so awesome. Since movies and anime are so wide, this is perfect.
One problem though. I can't connect it yet. They didn't give me any other things to connect it to the other input in my graphic card. So I am gonna go to the store tomorrow to buy it. I just need someone here to tell me the name of the one currently plugged in, and the name of the one I need to plug in the other one from the picture bellow. VGA-, DVI- and HDM, but I don't which one is which.
Image[/
Postby Zen » Wed Sep 09, 2009 14:52:14
I think blue is VGA and the white one is HDMI but im no expert so i might be wrong :P
Postby Baby-Boo » Wed Sep 09, 2009 14:57:04
saphi wrote:I think blue is VGA and the white one is HDMI but im no expert so i might be wrong :P
Sounds about right. I'll put the picture on my ipod and show it at the store to be sure.
Thanks SAPHI!!! the amazing one...
Postby bob » Wed Sep 09, 2009 15:10:04
Blue is VGA
White is DVI
Postby King » Wed Sep 09, 2009 16:38:45
bob wrote:Blue is VGA
White is DVI
This.
Postby RandomTask » Wed Sep 09, 2009 16:59:20
White is DVI
Confirmed.
You have a VGA plugged in currently, and the spare white slot is a DVI, not an HDMI.
Assuming your new monitor also has a blue plug you will want to get a VGA to DVI converter.
If you still have the box from your graphics card check in that, most of them come with one.
Postby King » Wed Sep 09, 2009 17:27:50
Yea that card will have come with one. Most the new ones come with DVI > HDMI instead these days. Mine had 2 i think, got loads of those VGA to DVI things kicking about tho.
Users browsing this forum: No registered users and 5 guests
