How would this system do?
Re: How would this system do?
Postby Razerslash » Sat Jun 20, 2009 18:18:09
Talho wrote:Only problem I ever had is that my 7600go from my laptop didnt want to install the standard nvidea drivers on it, so I had to go for omega drivers. (which actually gave me an fps boost lol :p)
Nvidia Go video cards are not supported by nvidia, the laptop supplier or 3rd party developers make drivers specific for them.
Postby Talho » Sun Jun 21, 2009 02:08:53
I know i know, but the drivers were pretty outdated :p 4 years old lol.
Brize
Teenage Mutant Ninja Turtle
Postby Brize » Mon Jun 22, 2009 15:13:19
Will prob buy this one
Behuizing: NoRRoD Midi ATX
Voeding: Recom Voeding 450 Watt
Moederbord: Asus P5KPL-AM
Processor: Intel Core 2 Quad Q9400
Cooler: Intel Boxed
Videokaart: Asus EN9800GTX+ DK/HTDI/512M
Geluidskaart: 5.1 onboard
Netwerk: 10/100/1000 Mbit/s onboard
Geheugen: 4GB DDR2 667MHz (2 x 2GB)
Harde schijf: Samsung SpinPoint F1 1TB SATAII
CD/DVD: Samsung DVD Rewriter SH-S223F 22x SATA
With the 1Gb version video card
Postby B00rz » Mon Jun 22, 2009 15:15:23
Sounds good how much is that costing you?
Postby Talho » Mon Jun 22, 2009 15:17:17
799 :>
Brize
Postby Brize » Mon Jun 22, 2009 15:20:38
ye including vista home pre
Postby Dimon » Mon Jun 22, 2009 15:31:45
What resolution are you playing on?
Brize
Postby Brize » Mon Jun 22, 2009 15:42:57
Dimon wrote:What resolution are you playing on?
1280 but on other screen prob 1400
Postby Dimon » Mon Jun 22, 2009 16:04:20
Ah, should be an ok setup then. With resolutions past that 1 GB VRAM is needed. Well for most games at least. \o/
450 W PSU is a bit low tho. nVidia cards are pretty power hungry.
That type of card seems to use 310 W on peak load.
That leaves 140 W for the rest of the system. CBA checking how much the other parts will need. But it will be cutting it pretty close at best.
That PSU will run pretty hot this summer, it better not be fan-less imho. XD
Postby King » Mon Jun 22, 2009 16:19:26
you will need a bigger PSU than that especially if u plan to add cd drives / hard drives etc. 450 was enough about 8 years ago, now you'd probably be better off with 600.
Users browsing this forum: No registered users and 93 guests
