Dimon wrote:Ah, should be an ok setup then. With resolutions past that 1 GB VRAM is needed. Well for most games at least. \o/
450 W PSU is a bit low tho. nVidia cards are pretty power hungry.
That type of card seems to use 310 W on peak load.
That leaves 140 W for the rest of the system. CBA checking how much the other parts will need. But it will be cutting it pretty close at best.
That PSU will run pretty hot this summer, it better not be fan-less imho. XD
King wrote:you will need a bigger PSU than that especially if u plan to add cd drives / hard drives etc. 450 was enough about 8 years ago, now you'd probably be better off with 600.
Talho wrote:The highest for a private person is 1066 anyway.
RandomTask wrote:Dimon, that is 310W for the whole system, not just the card. So 450 should be fine, assuming the test rig was roughly the same as Brizes set up...
RandomTask wrote:What? I have 1200Mhz..
RandomTask wrote:Talho wrote:The highest for a private person is 1066 anyway.
Users browsing this forum: No registered users and 26 guests
