How would this system do?
Chainey
Kung-Fu Panda
Kung-Fu Panda
Re: How would this system do?
Postby Chainey » Mon Jun 22, 2009 19:22:53
The reason you want more then 667 is only if your cpu is over
533mhz = 266 X 8 = 2.128ghz
667mhz = 333 X 8 = 2.668ghz
800mhz = 400 X 8 = 3.200ghz
Depending on what multiplyer your cpu has.. either its 7.5, 8 or 9 times.
667mhz = 333 X 9 = 3.0Ghz.
800mhz = 400 X 9 = 3.6Ghz.
So yeah :)
Postby Dimon » Mon Jun 22, 2009 20:15:16
Talho wrote:667Mhz is enough, the difference would be barely noticable with 800Mhz. Tho if you can buy it for like 10€ more, you should do it.
Loading times should be notably faster. ;>
When it comes to frames per second the difference will not be as noticeable as with a better GPU. And it's mainly for WoW, so saving a bit of money on the "second best" solution wont make that much of an impact. But imho having better RAM will be that little ekstra that will make it possible to wait longer for the next upgrade.
As it is now Brize will probably need to upgade more things next time.
With better RAM and a better PSU I think he'd be fine with only an GPU upgrade in 2 years.
Do you have a direct link to the voeding? ;p
Brize
Teenage Mutant Ninja Turtle
Postby Brize » Wed Jun 24, 2009 15:30:38
Alright i bought one let me show you as i made the topic what the end result is:P
Recom Voeding 450 Watt
Asus P5KPL-AM
Intel Core 2 Quad Q9400
Cooler: Intel Boxed
GeForce GTS250 DK 1G
Sound: 5.1 onboard
10/100/1000 Mbit/s onboard
4GB DDR2 800 Mhz (2 x 2GB)
Samsung SpinPoint F1 1TB SATAII
Samsung DVD Rewriter SH-S223F 22x SATA
Works sweeet
Postby Dimon » Wed Jun 24, 2009 16:25:10
Looking alright!
Tho I'm always skeptical about them mid range GPU's.
Postby King » Wed Jun 24, 2009 16:29:40
Dimon wrote:Looking alright!
Lol funnily enough i had the same thought, but im rather picky =P
Postby Dimon » Wed Jun 24, 2009 16:32:18
If I had the money I'd be sitting on 285's in SLi now. :<
Users browsing this forum: No registered users and 26 guests
