Forum activity
Re: Forum activity
Postby Baby-Boo » Tue Nov 25, 2008 06:41:42
24th of November 2008 - 18:24 o'clock attempt at perm banning someone - Failed
Re: Forum activity
Postby Baby-Boo » Sun Dec 07, 2008 18:20:00
Anyone wanna do the whole "console wars" crap debates. And maybe we can start insulting each other and each others mothers like they do on other forums.
If you don't like Xbox360... I will find you and rape you (kidders).
Re: Forum activity
Postby RandomTask » Sun Dec 07, 2008 19:27:40
ive never had a console. ever.
pc all the way.
Re: Forum activity
Postby Baby-Boo » Sun Dec 07, 2008 19:52:27
Can't handle the money use on it. I buy the best computer on the marked, one year later, it's weak now. And I am not that rich that I can upgrade it all the time. While consoles remain the same for 4-6 years, with the games improving.
Re: Forum activity
Postby Razerslash » Sun Dec 07, 2008 20:29:15
Consoles do not have crap running in the background i.e windows.. a console game is independant so it can just run straight off the hardware. So if you bought a PC that is equivalent to console hardware, you will find that the pc game cannot reach the same quality and performance as the console version. You will need a PC twice the power to do so. Plus the console hardware is made specificly.
Of course consoles run a OS too, but that takes up only a fraction of the performance. Thats why console games look better for years than even on some of the cutting edge PCs.
You can never keep up with cutting edge PCs, there is always something new out every week or so.
Re: Forum activity
Postby Baby-Boo » Sun Dec 07, 2008 21:35:50
Mac's don't get updates so much. I sit at the best they have at school, a 24 inch one. Gonna ask how equal it is to some Nvidia graphic card later.
Re: Forum activity
Postby Razerslash » Sun Dec 07, 2008 21:57:22
Baby-Boo wrote:Mac's don't get updates so much. I sit at the best they have at school, a 24 inch one. Gonna ask how equal it is to some Nvidia graphic card later.
Macintosh OS is so efficient, well programmed as well. They are also very hardware specific but its not impossible to buy a PC to run its OS, but why would you do something like that anyway...?
Hooogan
Re: Forum activity
Postby Hooogan » Mon Dec 08, 2008 01:20:13
Xbox 360 Pro + 6 Games is down from €600 to €299.99. What a foook'ing bargain, so I'll probably snag that up sometime in January.
I was going to hold out for a PS3 but I heard that MGS4 is going to be released for the 360, albeit on four discs but what the hell.
return 0;
Re: Forum activity
Postby Baby-Boo » Mon Dec 08, 2008 06:49:01
As the dude at school who handles all the computer fixes, he said that it's not smart to install windows on a Mac computer because it wont be able to update it self so easily that way or something.
Or maybe it was the other way around.
Hooogan wrote:I was going to hold out for a PS3 but I heard that MGS4 is going to be released for the 360, albeit on four discs but what the hell.
No it will not, there is only speculation about MGS5, but that rumour is not about 360 as everyone seems to think, and then everyone writes about it at and everyone believes it. The creator of the series would not go multi-platform.
Re: Forum activity
Postby Razerslash » Mon Dec 08, 2008 11:34:30
Its not gonna happen mate, 4 discs... There is a part in the game in MGS4 where it makes a joke refering to the 360 when otacon calls you in MGS1 to swap the disc from 1 to 2 but then forgets oh right your on the PS3 which has Blu-Ray...
Was kinda funny.
Anyway, if you think about it 4 DVD's for a game? I think if a number of cut-scenes were taken out and made into 2 DVD's then fine. But that would take half of the game out.
Plus its PS3 exclusive...
Even with MGS5, I don't think Konami will release that for xbox 360 as MGS5 will be even bigger and could possibly be made onto a 400gb blu-ray which has just been released.
Users browsing this forum: No registered users and 43 guests
