Battlefield 3
Re: Battlefield 3
Postby Rza » Tue Nov 01, 2011 00:37:51
try it capped at 32 for rush, currently 48 v 48 we had been playing on was too difficult. If 32 doesnt work then i'd 2nd the change to conquest.
Re: Battlefield 3
Postby Rza » Tue Nov 01, 2011 01:25:08
epic.
Re: Battlefield 3
Postby Rza » Tue Nov 01, 2011 01:31:44
Re: Battlefield 3
Postby Jupsik » Tue Nov 01, 2011 06:15:07
Rza wrote:try it capped at 32 for rush, currently 48 v 48 we had been playing on was too difficult. If 32 doesnt work then i'd 2nd the change to conquest.
48v 48 makes me get more kills as the chance of them being in front of my bullets is higher...
Re: Battlefield 3
Postby King » Tue Nov 01, 2011 08:39:27
Rza wrote:http://www.uiscommunity.co.uk/home/m/2472935/article/408963/page/2
May be a fix for you jonnie?
seen that last night on reddit. Already changed it, will see if it helps tonight
Re: Battlefield 3
Postby f1xxx3r » Tue Nov 01, 2011 08:46:18
I have the slow loading problem in BLOPS, it goes away after I reinstall my video drivers :o
I have to reinstall them after each reboot or aero won't start anyway so.
One might say my windows installation is a bit messed up.
Re: Battlefield 3
Postby Dimon » Wed Nov 02, 2011 02:32:09
Just remembered to use my Physical Warfare-pack code. >.>
Re: Battlefield 3
Postby Rza » Sat Nov 05, 2011 00:50:12
Re: Battlefield 3
Postby RandomTask » Tue Nov 08, 2011 19:06:25
Re: Battlefield 3
Postby Rza » Tue Nov 08, 2011 19:56:02
http://twitter.com/#!/Demize99/status/1 ... 3617898497
Developers are listening to community, this is always a good thing.
Users browsing this forum: No registered users and 114 guests
