How would this system do?
Brize
Teenage Mutant Ninja Turtle
Postby Brize » Fri Jun 19, 2009 16:33:41
Right i configured some kind of system on a website and want to know if it is good for gaming... Cause i have such shit fps atm ><
PROCESSOR Intel® Core™2 Quad Core-processor Q8200 (2,33 GHz, 1.333 MHz, 4 MB cache)
MEMORY 4.096 MB 1.333 MHz Dual Channel DDR3 SDRAM [2 x 2.048]
HDD 640 GB Serial ATA non Raid (7200 Rpm)
VIDEO 512 MB ATI® Radeon™ 4850 grafische kaart
Help me :p
Re: How would this system do?
Postby Razerslash » Fri Jun 19, 2009 16:42:44
Whats the price? Looking good though but you could look for a higher ram on the video card, most recent games rely on it the most.
Brize
Postby Brize » Fri Jun 19, 2009 16:52:41
780 euros. i could link the whole page but its written in dutch ><
But would that videcard run like decent games any good on high details? For example wow, gta4? My current one does like 40 fps on low settings only and in wow 25 man raids barely 20.
edit: 32 bit
Postby Razerslash » Fri Jun 19, 2009 16:54:10
Hope you got a 64Bit OS for that 4GB RAM =P. 780 sounds reasonable, but would invest into a more RAM video card.
Postby Talho » Fri Jun 19, 2009 17:10:13
780 is to high :p I know a lot of good shops in southern part of holland just tell me where u live and I'll try to find a close cheap shop :>
anyway a system from 800€ should look like this
AMD X4 945 Phenom II 64BIT Quad-core Processor AM3 Boxed With 209,00
Antec Sonata III 500W Black Recupel recyclagebijdrage inbegrepen 126,90
Samsung HD103UJ 1000GB (1TB) 32MB SATA300 7200RPM 79,00
MSI K9A2 Platinum Socket AM2 134,90
MSI R4890-T2D1G-OC HD4890 1024MB DDR5 PCI Express Radeon 4890
209,00
NEC AD-7200S-0B Zwart S-ATA 20X DVD-RW 29,90
Corsair Twinx DDR2 4096MB PC6400 XMS2 (2X2048MB) 49,00
totaal : 840 (in belgium, but holland is a bit cheaper)
YES AMD SUCKERS :p but for the graphics card, with 50€ more u can buy a GTX
Postby Talho » Fri Jun 19, 2009 17:12:16
Brize wrote:780 euros. i could link the whole page but its written in dutch ><
edit: 32 bit
for WoW it doesnt matter much which graphics card u have, doesnt like high end cards anyway.
for gta4 you need a 1GB video card to play it decent, specially when you play on a bigger resolution then 1280.
Postby King » Fri Jun 19, 2009 17:17:43
you'll need vista or win7 64bit if u want to use 4gb of ram. Dont trying using xp 64bit thats a waste of time =P
Postby Talho » Fri Jun 19, 2009 17:24:12
buy a pc without vista :> much cheaper, hasnt to be illigal, dont you study informatics, dont you have free cd-keys ?
I got like 4 vista keys :p, Vista32 dutch, Vista64 dutch, Vista32 + sp1 eng, Vista64 + sp1 eng. already got me a windows7 key 2 :> but not sure, it can be beta.
Postby RandomTask » Fri Jun 19, 2009 17:28:43
Yeah if you can borrow one (e.g yer dads) then you can save £100 and spend it on a better card.
So you know, my shitty Core 2 Duo E6600 2.4Ghz can run Fallout 3 at maximum settings @ 1920x1200 with great FPS rates, purely because my GTX 260 OCX MaxCore does all the work for it.
IMHO, for gaming get the best GPU you can, followed by 4GB of fast RAM and then whatever CPU you can afford to get after those two parts.
Postby Talho » Fri Jun 19, 2009 17:34:54
RandomTask wrote:Yeah if you can borrow one (e.g yer dads) then you can save £100 and spend it on a better card.
fallout isnt that great,my 4870 pulls that off easy, try GTA4 :p, you wont be able to play it on max setting, mine already uses 1GB video ram at 1680, with 1 or 2 options not on ultra.
but ye you should save on cpu, so buy AMD, and you will also save on your motherboard then since intel motherboards r always more expensive.
Users browsing this forum: Baidu [Spider] and 23 guests
