needed more threads/ new pc time #2
Postby Jupsik » Mon Sep 20, 2010 20:09:02
CPU: Intel Core i5 760 2.8GHz (http://ark.intel.com/Product.aspx?id=48496)
• cpu cooler: AC Freezer 7 Pro rev2 (http://www.arctic-cooling.com/catalog/p ... 42&mID=304)
• mobo: GIGABYTE GA-P55-US3L (it basically supports crossfire, but thats about it, no sata 6gb/sec or ubs 3, but chances are i wont be using 1 anyways) http://www.gigabyte.com/products/produc ... id=3502#ov
• Ram:hyperx 2x2GB DDR3 1333MHz CL9
• GPU: ATI HD5770 1GB DDR5
• HDD: 500GB 7200 SATAII 16MB http://www.wdc.com/en/products/products.asp?driveid=301
• Toiteplokk: Xigmatek 500W (its an 82+ supply, not much else that i know about it)http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=128
thinking of buying it tomorrow unless someone finds some good reasons not to...
Re: needed more threads/ new pc time #2
Postby Kidders » Mon Sep 20, 2010 20:29:53
DDR5? i've fallen well back in technology
Postby Jupsik » Mon Sep 20, 2010 20:45:12
ddr5 for gpus has been out for like 3 years (ive actually got no idea how long its been out)
Postby B00rz » Mon Sep 20, 2010 21:27:18
been a while
Postby Jupsik » Mon Sep 20, 2010 21:40:29
so the pc is=P?
Postby Dimon » Tue Sep 21, 2010 00:04:40
DON'T DO IT!
Unless it's reasonably priced. Then just go ahead and get it tbh. :p
Postby Jupsik » Tue Sep 21, 2010 06:11:38
its 550 pounds
Postby Jupsik » Tue Sep 21, 2010 11:32:00
ordered
Postby King » Tue Sep 21, 2010 11:56:03
Tis a nice spec for that price good choice for sure.
Postby B00rz » Tue Sep 21, 2010 11:57:16
Why didnt you pay the extra 20 euros and get the 1600mhz ram?
Users browsing this forum: Google [Bot] and 29 guests
