TV
TV
Postby RandomTask » Thu Dec 30, 2010 22:39:14
Any of you guys recommend any decent TV's?
32-37", £500-600, 1080p, LED, 100/200Hz etc?
Re: TV
Postby Jupsik » Fri Dec 31, 2010 10:06:08
id recommend the 32le5400 from lg, never had any problems with anything from lg. The picture quality is excellent, the only can are the inbuilt speakers. they are decent, the sound is clear but the bass is a bit of a letdown.
*edit*
fixed =P
Re: TV
Postby Kidders » Fri Dec 31, 2010 15:05:00
bass man!
Re: TV
Postby King » Sat Jan 01, 2011 02:03:58
Anything Sony, LG or Samsung tbh, never had any issues with any of them.
Re: TV
Postby Jupsik » Sat Jan 01, 2011 11:28:37
King wrote:Anything Sony, LG or Samsung tbh, never had any issues with any of them.
that can back back u up on the sony and lg part, no idea about samsung
Re: TV
Postby Rza » Sat Jan 01, 2011 15:36:43
Keep an eye on ibood.com, I got my Samsung LED 37" for £479 a few months back. Best deal ever!
KoLdDoOm
Kung-Fu Panda
Kung-Fu Panda
Re: TV
Postby KoLdDoOm » Sun Jan 02, 2011 17:19:36
I sell LG, Samsung and Toshiba's at my work, and used to sell Sony and Panasonic at an old job, and what I've found as a very general observation -
LG are my favourite out of the brands, got myself a 26LU5000 about 9 months ago and I love it. For a 37" you can't go far wrong with the 37LE5900 (recently bought this model for my lounge actually), it's a fairly new model, Full HD Edge LED, 100Hz, also it's got Freeview HD so if you don't have Sky HD or anything like that, you can still make the most of the 1080p with general TV watching. Pretty sure the only models above it are the 3D ones but I might be wrong. We sell em for £649.99 but bear in mind we're VAT-less in Guernsey. My PS3 looks sexual through it =P
But yeah, you can also get that model in a 32" (32LE5900), not sure what kinda price but I'd estimate around the £530 mark.
Samsungs are good, better design than LG no doubt, but I find their menu system less intuitive and you pay a bit more for the nicer design, personally I don't care too much about the shape of the stand or whatever (alot of Samsung's have this chrome spider stand now rather than the plastic/glass block stand that you get on other TV's e.g. LG's), I'd rather spend the extra money on getting a higher spec TV than a nicer design. Only thing is, if you're wall-mounting, Samsung are pretty smart with their LEDs in that they have all the HDMI's on the side rather than facing the back, and the SCARTs and Coax plugs are done with extensions rather than straight onto the back, so you can have it flush to the wall. The equivalent to LG's 32LE5900 would probably be: http://www.amazon.co.uk/Samsung-UE32C65 ... 669&sr=1-1
We've had 'em in the shop before and they are stunning TV's, but a bit overpriced for what they are IMO.
Finally, Tosh I wouldn't touch these days, they're decent enough I guess but all of the LCD Toshiba's I've seen lately have terrible viewing angles, and horrible design, haven't seen much of their LED range mind.
Sony and Pana were both good when I last saw them but you're gonna be paying a bit more for similar specs to the LG/Samsung specs, I reckon. Don't know much about their current ranges though.
Finally, the speakers in all of the LED models that I've seen are pretty shocking to be fair (although you can probably understand that being that it's a TV around 3-4CM in thickness at the most, and they're putting speakers in that will fit that design ;p) so if you go LED you're probably gonna want a home cinema system or something for serious movie watching or anything, however they're decent enough for just TV and stuff.
Asus P8Z68-V LX Intel Z68 | Intel Core i5 2500k @ 4.20GHz | 8GB DDR3 1600MHZ | ATI Radeon HD 6950 2GB OC @ 840/1250 | 64 GB Crucial SSD Boot Drive | 1 TB Seagate Barracuda SATA 6gb/s HDD | LG e2250v 22" 1080p LED Monitor | Saitek Cyborg V5 | Razer Imperator | Steelpad 4D
Re: TV
Postby RandomTask » Sun Jan 02, 2011 20:30:45
Yeah I've had Samsung and LG monitors in the past and both have been great.
Not worried about Freeview as I have Sky+HD already, and will be using my PC speakers etc. so not worried about sound quality either.
I'll be wall mounting it so will check out that Samsung one, but the LG 37LE5900 is pretty sexy ;D
KoLdDoOm
Kung-Fu Panda
Kung-Fu Panda
Re: TV
Postby KoLdDoOm » Sun Jan 02, 2011 20:57:08
Idd, I've got a 22" LED LG Monitor as well actually, it's awesome. Since you're wall-mounting, I'd say Samsung all the way - if you can see the back of a Samsung and then an LG you'll see what I mean - 1 SCART plug, and a flush wall-mount is impossible with the LG's rear design, it's ridiculous. Obviously it doesn't matter if you're putting it on a tilt & swing bracket, but if you're mounting it flush to the wall, then Samsung FTW
Re: TV
Postby RandomTask » Sun Jan 02, 2011 23:14:53
Aye it'll be tilt and swing (hur hur) so I'll be all good with either I suspect. Will let ye know which one I go for when I actually buy it.
Users browsing this forum: Baidu [Spider] and 23 guests
