Headiephonies
Headiephonies
Postby RandomTask » Sun May 22, 2011 15:47:06
Aye so I fancy getting some new headphones. A decent set of wired ones for the PC. Circumaural w/without microphone. Will mainly be for louuuuuuuuuuuuuud music but also films and games too.
Any suggestions? Have had Sennheisers in the past which have always been pretty awesome.
Re: Headiephonies
Postby Rza » Sun May 22, 2011 19:14:12
I use the Sennheiser PC360's which is basically just the Sennheiser HD550 (which had before and had a siberia mic) with a microphone. The volume control is also on the ear cup plus to mute your mic you just flip the microphone upwards. These 2 features alone makes me love them. I accidently snapped the mic when the cable got stuck under my chair and ripped it off and ended up forking out another £100 - I've tried a lot of headsets and nothing come close to these for sound, comfort and quality. I use the broken mic set now on my tv when watching films now :>
Their open ear which not always to everyone's taste as their pretty much like speakers on your head.
http://www.sennheiserusa.com/pc-professional-gamer-gaming-headset-noise-cancelling-pc-soundcard_504122
If you can blow the budget then look at some of the top end audiophile headsets on their too. Of course all is pointless unless you have a decent soundcard.
Its about 2 years old now but the Asus Xonar Essence with headphone amp is awesome - Might be new versions of it these days but you'll be hard pushed to find a bad review about it.
Re: Headiephonies
Postby Jupsik » Sun May 22, 2011 20:17:49
im using noise canceling ones from bose, sound is brilliant also best noise canceling out there. + their super light yet with a solid feel so u wont get tired from using them for like 8 hours straight
http://www.bose.com/controller?url=/sho ... /index.jsp
Re: Headiephonies
Postby RandomTask » Fri May 27, 2011 17:58:28
Went with the PC360s too. They are winsome indeed.
Users browsing this forum: Baidu [Spider] and 21 guests
