PC Upgrades
PC Upgrades
Postby RandomTask » Sun Jun 24, 2012 09:16:41
Aye, so, thinking I might upgrade my PC with new CPU/Graphics/RAM potentially, however I have paid literally less than zero attention to developments over the 2 and a half years since I got this. This is what I have just now:
From the quick read I had last night it sounds like I wouldn't gain much from a CPU/Ram upgrade, so maybe just a new graphics card..or two?
My initial thoughts are:
http://www.aria.co.uk/SuperSpecials/Other+products/MSI+Twin+FrozR+II+GeForce+GTX+570+OC+1280MB+GDDR5+PCI-Express+Graphics+Card+?productId=50317
Anyone got some suggestions?
Re: PC Upgrades
Postby Dimon » Sun Jun 24, 2012 12:06:21
Re: PC Upgrades
Postby Rza » Sun Jun 24, 2012 13:24:22
I've got the older version of that - the 580GTX - its a really awesome card
Re: PC Upgrades
Postby Jupsik » Mon Jun 25, 2012 18:19:12
Get an amd 7970, its better at higher resolutions then the 680 and its cheaper. That said both cards deliver around the 100 fps mark on 1080p resolutions - so i see no reason to buy a more expensive 680 for a performance increase you won't see. And as you have 30'' monitors then I think the 7970 is better anyways.
Re: PC Upgrades
Postby RandomTask » Mon Jun 25, 2012 18:36:48
Jupsik wrote:Get an amd 7970, its better at higher resolutions then the 680 and its cheaper. That said both cards deliver around the 100 fps mark on 1080p resolutions - so i see no reason to buy a more expensive 680 for a performance increase you won't see. And as you have 30'' monitors then I think the 7970 is better anyways.
Think the Motherboard is nVidia only.. Might be wrong though..
Re: PC Upgrades
Postby Dimon » Mon Jun 25, 2012 19:56:58
Won't matter what GPU you put in. Unless you want two. But one single card is usually a better solution unless you're getting top tier performance cards. Then you may be in trouble if the card is SLi only. But it's not uncommon for motherboards to support both SLi and CrossFire now.
Re: PC Upgrades
Postby Jupsik » Tue Jun 26, 2012 00:28:49
usually amd motherboards didn't support nvidia and intel used to support both. But yeah what dim said, for a single screen set-up there is no need to crossfire if you using the gtx 680 or 7970. They both are complete overkill for single screen resolutions.
Users browsing this forum: Baidu [Spider] and 21 guests
