New PC, recommendations
Postby Rza » Mon Jan 26, 2009 14:50:10
Hi all thinking of upgrading my pc as mine is getting a bit outdated and seeing as so many of you'd know what your talking about in here I'll come here first as am not clues up on the latest hardware these days.
Basically I'd rather not build it myself this time around so kind of looking at a custom built one made one:
Budget min £600 max £1000. Cheaper the better preferably
I want it for multimedia use, so large harddisk, decent sound/gfx etc etc
Don't need a monitor
Anyone came across any nice deals recently? Or can point me in the right direction?
Any help is appreciated, also apologies if this post has bad spelling doing this from my phone and it uses predictive text
Cheers
Re: New PC, recommendations
Postby Talho » Mon Jan 26, 2009 15:55:17
ANTEC sonata
MSI K9A2 Platinum (4x PCI Express x16, AMD® CrossFire™ 790FX and SB600 Chipset, 4 Dual Channel DDRII 1066, 4 SATA II raid (0 en 1), 8 Channel Sound, Dual Gigabit LAN, 2 Firewire, 10 USB2.0)
AMD X4 920 Phenom II 64BIT Quad-core Processor AM2+ Boxed Withcooler
Corsair Twinx DDR2 4096MB PC6400 XMS2 (2X2048MB)
Samsung SH-S223F/bebe Zwart S-ATA 22X DVD-RW
Samsung HD642JJ 640GB 16MB SATA300 7200RPM
Gigabyte GV-R487D5-1GD 1024MB DDR5 PCI Express Radeon 4870
Antec Earthwatts 2.0 500WATT
this my my pc for about 900€ (without windows this is) so do the math :>. There is still an option to use crossfire later as there is a slot open. Don't think the prices in GB is much different.
When did £ drop so low btw ?
Postby Razerslash » Mon Jan 26, 2009 17:20:01
Talho wrote:Don't think the prices in GB is much different.
It will be roughly the same from GB to EURO as its almost 1:1.
Postby Kidders » Mon Jan 26, 2009 17:53:59
if i was you i'd probably stick to core2duo and get a decent one of them rather than getting an early quad core.
umm... i have a nividia 8800gt, which is very good for the price if you're looking for something with punch that's cheap. random could probably help in that department.
Dunno about much else since I upgraded last christmas.
Postby Talho » Mon Jan 26, 2009 19:01:16
4870 > 8800/9800 by far :>
and that AMD phenom is quite good, it's been a while since AMD made another good cpu that keeps up with INTEL
Postby RandomTask » Mon Jan 26, 2009 19:27:26
My typical PC budget is more like £1500-2000, so here is one nearer the top end of your price range.
I would look along the lines of:
CPU: Intel Core i7 920 £230
MOBO: Asus P6T Deluxe V2 £250
GFX: BFG GF GTX 260 896MB OC MAXCORE £230
RAM: 3GB OCZ PC3-12800 1600Mhz £115 (I originally had 6Gb here but it turned out abit too pricy)
HDD: 1TB Samsung Spinpoint F1 £75
PSU: OCZ 700W ModXStream Pro £80
Sound: Creative X-Fi Xtreme Gamer £60
£1040
Thats assuming your going to reuse the case, dvd drive etc as these are pretty pointless upgrading until they die.
I realise you mentioned you would rather not build it yourself but to be honest you get alot more value for money if you do.
That set up there is the third best CPU you can get, 2nd best GFX card, medium spec ram, with a motherboard that will comfortably take the best CPU around just now as well as 24GB (lol) of 2000Mhz DDR3 ram.
I havn't really looked at reviews for most of that, but the specs are all good/match up etc.
The PSU would need to be better if you were going to consider SLI/xFire (the motherboard can do either if you prefer ATI over nVidia, also supports 3way SLI and Quad GPU's)
You could get slower ram as well and save some money, but personally if I did anything with the ram it would be getting more/faster.
You could also get a cheaper motherboard but again I typically get one of the best motherboards. Normally I just look at the most expensive CPU there is at the time and get a motherboard which would run that, with the expectation that I'll upgrade to that CPU within a yr/two when its halved/quartered in price.
I just picked a random 1TB drive, again you would probably want to look at it in abit more detail and perhaps get a quieter one if you plan to use it mainly for movies etc as one of my main design criteria for my new pc is going to be getting it as quiet as possible as it really fucks me off at the moment.
Also I'd recommend trying to sell your old PC, as it normally comfortably pays for at least one new component of the new PC, if not 2 or 3 giving you an extra £200/300/400 to play with.
Postby Baby-Boo » Mon Jan 26, 2009 19:32:43
Or a quicker way. look at the price of a comp, look at the graphic card, and just buy it!
Don't listen to them. Their nuts with all their numbers and words that I don't understand.
Postby RandomTask » Mon Jan 26, 2009 19:34:37
Baby-Boo wrote:Or a quicker way. look at the price of a comp, look at the graphic card, and just buy it!
..and get ripped off.
Postby bob » Mon Jan 26, 2009 20:58:17
Seems like a pretty good spec from Random IMO.
Pretty sure u can get the parts cheaper if u shop around but not 100% sure as I buy all my parts from a shop that is owned by a m8 so get nice discount.
Postby RandomTask » Mon Jan 26, 2009 21:01:28
bob wrote:Seems like a pretty good spec from Random IMO.
Those were pretty much the cheapest I found on www.froogle.co.uk but I didnt look into it too much.
Users browsing this forum: No registered users and 23 guests
