elstatsneo
HiTmAn
elstatsneo
Postby HiTmAn » Thu Feb 12, 2009 01:13:12
Hi.. i was trying to install elstatsneo on a webhost to create a ranking to our pub server, like the old one..
well the problem is that webhost don't received any data yet..
or if received, it not update lol
i use the port 21, not the 27500.. is any problem for use that port?
i add the lines log on and log adress in autoexec.cfg in gameserver..
i executed the script with crob jobs on run_hlstats and it said:
"Starting ELstatsNEO...
PID file created
Started successfully"
i can't find the problem..
can anyone help me?
thanks
Re: elstatsneo
Postby Dimon » Thu Feb 12, 2009 01:23:31
Isn't port 21 the standard one? ;p
Dunno why that should be the issue.
Could be the webhost itself imo.
HiTmAn
Re: elstatsneo
Postby HiTmAn » Thu Feb 12, 2009 01:34:17
Tenyo wrote:Could be the webhost itself imo.
what could be the problem on host?
Re: elstatsneo
Postby Dimon » Thu Feb 12, 2009 07:35:32
Some webhosts are slow at times, once transferred a file over FTP, just to only find it more 24 h later. :p
Re: elstatsneo
Postby King » Thu Feb 12, 2009 07:55:09
port 21 is FTP port, so yes there's a problem using that port. Also you need to make sure that the perl script is running, and using the same port configuration. This is what collects the data.
HiTmAn
Re: elstatsneo
Postby HiTmAn » Thu Feb 12, 2009 21:28:16
yup.. so i change on hlstats.conf port to 27500..
i must change now on gameserver in autoexec..
i send a ticket to webhost admin to open port 27500.. and he said this:
"There is nothing running on our port 27500, so of course it responds with an error. That does not mean that it is blocked. Even if we were running a firewall, the firewall would block inbound traffic, not outbound, which is what you are trying to do. You are trying to connect to port 27500 not OURS but on the gameserver. This is an outbound connection, and nothing blocks that on our part
Regards"
can you explain me this? cause or i am wrong or he didn't understand my problem..
gameserver must send data to my webhost..
to port 27500..
so this must be open, it isn't?
Re: elstatsneo
Postby Kidders » Thu Feb 12, 2009 22:21:56
do a barrel roll
HiTmAn
Re: elstatsneo
Postby HiTmAn » Thu Feb 12, 2009 22:23:29
loool
other thing.. 27500 gameserver's port, must be open too?
Re: elstatsneo
Postby King » Fri Feb 13, 2009 00:05:39
just the webhost must have 27500 port open. and the webhost must be running the perl script to recieve the data.
HiTmAn
Re: elstatsneo
Postby HiTmAn » Fri Feb 13, 2009 00:18:58
perl cfg is hlstats.conf?
this cfg is running..
now i must wait for a admin's webhost answer
Users browsing this forum: No registered users and 40 guests
