Triada - Hunter - Marksmanship
Triada
Postby Triada » Sun Apr 18, 2010 01:18:10
Character Name: Triada
Class: Hunter :hunter:
Spec: Marksmanship
Andrey
Age?
19
Nationality?
Russian
Ofc i can speak and understand it :)
AE raids 3 times a week: Wed, Thurs, Sunday 20:30 - 23/24:00? We expect 100% Raid attendance on these nights can you make these times okay?
i'm available almost all the time and those times are okay.
Have you got Teamspeak3 ? We are a very sociable group and are always talking on TS3, Although not mandatory are you prepared to Talk on TS/Vent (Not Just listen)?
Yes i have TS3. and ofc i would be glad to communicate with the guild as much as possible.
Do you know or have any friends currently in the guild? If not do you know a player (such as an ex-GM/Officer) we could approach to enquire about you? (optional)
No, i'm currently unknown to the After Effect, unfortunately :(
Saw your members many times. And after i hit lvl 80, i've asked couple your members about the website.
7/57/7 + Glyphs of: Serpent Sting, Steady Shot and Rapid Fire
Why are you this spec? Why have you Geared/Gemmed/Enchanted in a particular way? Explain?
I was using marksmanship all the way through the leveling. And I still love it.
My PvE gear's GS is 5084 atm.
I will replace all my gems for arp ones as soon as possible, because i've started geming in the wrong way.
I prefer gear with no haste but with loads of armor penetration, and ap. Still missing like 0.5% of hit to cap, will be caped soon.
+ It would be nice if someone experienced would give me couple hints at playing mm hunter in raids :)
Hunter's mark + Kill command (if not on CD), serpent sting, arcane, aimed, chimaera, steady, steady, arcane, steady steady, aimed, chimaera, steady, steady etc. + using, rapid fire, berserk, hyperspeed acelerators and call of the wild every time they are ready.
I was guildless since character creation and up to lvl 80, then i joined Templars of Steel, but every time they've planned any raid, most of the officers + guild master were saved separately, thats why i left them.
Prior raiding experience? (WOLTK only)
Three bosses in ICC 10 so far... Still working on getting better gear.
Ofc. Though you got an awesome website, which i would rate a 5+ one.
Post a link to a screenshot of your UI? (Optional)
http://img85.imageshack.us/img85/7994/w ... 040946.jpg
Post a link to any previous WoL Raid Reports of DPS/HPS? (Optional)
Not Completed By Applicant
Any Final Words? (Your chance to to tell us a bit about you)
I like your guild very much and i would be glad and proud to be your member since now and forever.
WoW Armory Link: Triada
Re: Triada - Hunter - Marksmanship
Postby Zen » Sun Apr 18, 2010 11:25:27
Like the app, wait for our hunter CL takes a look.
Postby f1xxx3r » Sun Apr 18, 2010 19:08:06
App is good but your gear is behind our current 25 man progress. Also there's a lot of pvp pieces I'm seeing (trinket, wrists, cloak and neck).
Would be more than happy to give you a trial after you get some better gear.
So unfortunately it's a no from me.
LE: Be sure to check the spreadsheet/femaledwarf if you're in the point that ARP > AGI gemming. It greatly depends on gear. Your agi is extremely low.
Triada
Postby Triada » Sun Apr 18, 2010 20:45:17
Sad to hear that :(
It's nearly impossible to get better gear than i have at the moment. Because, for example, cloak requires 17 more emblems of frost, which i can only get by doing one first random heroic per day, which would result 9 more days to get. I'm trying to get second pve trinket from forge of souls almost since i've dinged, already killed Devourer of Souls 30 times according to statistics, and I haven't seen it drops at all...
Then, neck and and wrists, I just can't find a replace for them in the curent heroics which wouldn't be a 213 or 232 iLevel. I will lose much AP and crit if i will replace those two items for a pve ones with 213 or even 232 iL...
Maybe there is still a way for me to be accepted? I knew that i'm not geared well enough for 25 pll ICC, but you got couple groups which still raid 10 ppl, if only i could have joined them for atleast 3-5 bosses... Everyone should gear up somehow, I would be happy to go atleast somewhere with your guild. I really like it so much... And i'm almost in a despair after you posted your reply :(
Phantomancer
Cobra Kai Sensei
Cobra Kai Sensei
Postby Phantomancer » Sun Apr 18, 2010 21:11:01
Triada wrote:It's nearly impossible to get better gear than i have at the moment.r
Do not worry. You can upgrade your gear easily. Download a spredsheat ( ex. Rawr )
With his you can upload your profile and get a clue on what upgrades you can aim for.
And for a player without guild you can get alot of emblems on one week :)
7x daily = 14
voa = 4
Weekly raid = 5
icc10 = 8 (prob more since you can get quest or more bosses)
icc25 = 8 (Same here)
This is 30-40 emblems every week. So its not that hard to get upgrades.
Darkmoon Card: Greatness is also a great starter trinket.
But again download rawr and you will see what you can do for upgrades.
Godspeed.
"When I get sad, I stop being sad and be awesome instead"
Triada
Postby Triada » Sun Apr 18, 2010 22:05:08
so this is going to be moved to "Declined Applications"... =(
Postby Jupsik » Mon Apr 19, 2010 09:02:32
it does look impossible to start with, but try pugging toc 25 and icc 10/25 and it'll go up fast
Return to Declined Applications
Users browsing this forum: Bing [Bot] and 2 guests
