How would this system do?
Brize
Teenage Mutant Ninja Turtle
Re: How would this system do?
Postby Brize » Fri Jun 19, 2009 17:40:12
Ye ill look for a better system then but i dont want to spent more then 800 ><
Postby King » Fri Jun 19, 2009 17:40:56
bah intel and pentium is far better for performance these days, as such go with nvidia also don't listen to talho he's an idiot *see the AFK forum for more details on this*. It might be a bit more but you get what u pay for then.
Most modern games are tending to offload a lot on the GPU rather than the CPU which is a nice move tbh, obviously a decent CPU still helps. My setup is similar to randoms but with a Q6600 Quad Core and the OC2 version of that card. And i i can run games at that res with decent FPS, however wow doesn't cooperate =P
Postby Talho » Fri Jun 19, 2009 17:55:29
tried to make one on alternate.nl, which is one of the best shops in holland.
anyway this one is 750€ but i couldnt seem to get the same cpu in it with that configurator, so the price should be 30€ higher then this one
Grafische kaarten ATI Radeon HD4000
MSI R4890-T2D1G-OC
ATI Radeon HD4890, 1024 MB, 256 Bit, PCIe x16 v2.0
1
€ 199,-
€ 199,-
CPUs Socket AM2+
AMD Phenom X4 9950 Black Edition
4x 2600 MHz, 4x 512 kB, 4000 MT/s, Agena
1
€ 145,-
€ 145,-
Boxed Koeler (ATX Layout, PWM)
1
Behuizingen Midi Tower
Antec Sonata III
3 x, 4 x, 500 Watt, ATX
1
€ 119,-
€ 119,-
Earthwatts
500 Watt, ATX12V 2.2, ATX 2.03, EPS, 4 x, 6 x
1
fan 120mm
120 mm
1
DVD-reWriters IDE
Pioneer DVR-117DBK
22 / 8 / 12 speed, 22 / 6 / 12 speed, Ultra DMA/66, 16 / 40 speed
1
€ 25,-
€ 25,-
Moederborden Socket AM2+
MSI K9A2 Platinum
AMD 790FX (RD790), 5.200 MT/s, 4x PCIe x16 v2.0, Socket AM2+
1
€ 125,-
€ 125,-
Ultra DMA/133 Controller
maximaal 2 apparaten, 133 MB/s
1
ATI SB600 Southbridge
maximaal 4 apparaten, RAID 0, 1, 0+1, 300 MB/s
1
Serial ATA/300 Controller
maximaal 2 apparaten, 300 MB/s
1
USB 2.0 Controller
60 MB/s, USB 2.0, maximaal 127 apparaten
1
FireWire Controller
50 MB/s, FireWire, maximaal 63 apparaten
1
Realtek ALC888 (HD-Audio; 8-channel)
3 x Line-out, 1 x Optisch-Uit, Realtek ALC888
1
Realtek RTL8111B
1
Harddisks 3,5 inch SATA
Seagate ST31000333AS
1.000 GB, 8,5 / 32 / 7200, € 0,08*, Serial ATA/300
1
€ 85,-
€ 85,-
Geheugen DDR2-1066
Corsair 2 GB DDR2-1066 Dominator EPP Kit
2048 MB, CL5 5-5-15 2T, 2 stuk(s), PC2 8500
1
€ 49,-
€ 49,-
Subtotaal:
€ 747,
Postby Talho » Fri Jun 19, 2009 17:57:20
King wrote:bah intel and pentium is far better for performance these days, as such go with nvidia also don't listen to talho he's an idiot *see the AFK forum for more details on this*. It might be a bit more but you get what u pay for then.
I have no idea why u keep on bashing that intel and nvidea should have better performance/price ratio :/ It's like saying IPhone has the best smartphone, just cause of the big brand name. Stop being such a fanboy :p
just look up some reviews, benchmarks and its all pretty clear to me.... AMD is atm the better gamer choice
Postby RandomTask » Fri Jun 19, 2009 18:46:25
What benchmarks are you looking at?
Intel and nVidia are always at the top on the ones I see...
CPU Benchmark on Crysis: http://www.tomshardware.co.uk/charts/de ... 0,818.html
GPU Benchmark on Crysis: http://www.tomshardware.co.uk/charts/ga ... 1,758.html
As an aside, I bought the Samsung i900h/Omnia as it was touted as being an 'iPhone Killer' with reviews placing it miles ahead of the iPhone. Oh how I regret that decision.
Postby Rza » Fri Jun 19, 2009 19:36:14
Oi you keep going on about fanboy stuff, but your the one like a fly round shite when it comes to ATi, defended it to the bitter end!
Let me tell you why I will never buy another ATI card again.
From personal experience with ATI, when i got my new pc from Overclockers.co.uk, booted it up, nothing but postcode errors. Sent it back - RMA came back: Faulty GFX card.
Got a replacement, when i tried to play COD4, I couldn't, down to crappy unstable drivers that would lagg every like 5 sec's then black out to desktop. Searching the error I got it was a common problem on vista and their was no solid answer on how to solve the issue - even from ATI support didnt have a definative answer.
3 days or so later the gfx card dies again.
So at this point had enough, sent it back and sure enough RMA: Graphics card confirmed as faulty. Got my money back and bought the Nvidia BFG GTX260 or w/e it is can't remeber exactly, and has zero issues since. The only difference of 2 cards is slighly lower FPS on the nvidia card, nothing thats ultimately gamebreaking off a difference.
Am not exgeratting about anything above ethier, you'll all prob remeber me moan about them at some point on TS, so this is why I will always recommend Nvidia and not ATI, got feck all to do with what some nerds bashing ATI on tech websites say.
Postby King » Fri Jun 19, 2009 19:36:34
idd random.
Plus all the ati cards of personally had experience with have either broken, had serious driver flaws, overheated, or simply not worked straight out the box. Hence, i'll never buy another ATI card. Ever.
Edit, and while i wrote this rza posted that too, see two different people with very similar problems with ATI, clearly ur the fan boy sticking with them after such obvious faults =P
Postby Rza » Fri Jun 19, 2009 19:48:12
And also, should add, I have an Iphone aswell and nothing I've seen even comes close to it terms of what I use it for - fast internet, quality video playback, plenty of memory, tonnes of applications that go beyond anything else on any other phones pretty have. The stuff is pretty much endless on it.
The only factor is the Price.
Seeing as your basically typecasting me and others here as people who'll buy anything you see on TV - Your jumping on the bandwagon looking at it from the point of view of all these elitist assholes from websites who will do anything to bash a company purely because its mainstream and making money.
Have your own opinions already! :P
Postby B00rz » Fri Jun 19, 2009 21:26:52
talho has left the building =D
Postby RandomTask » Fri Jun 19, 2009 21:30:40
Rza wrote:...but your the one like a fly round shite when it comes to ATi...
Made my day.
Users browsing this forum: No registered users and 66 guests
